Rough running on fast idle.
Unklian
Post by Unklian »
Hi Everybody.
Long story short......
Rockster is serviced / tuned / new plugs /
Filter / TB Balanced / Injection reset.
Starting from cold, the Rockster runs rough, almost like one cylinder until
it is warmed up then behaves perfectly, no surging or anything.
The question is,......
Does the fast idle affect the 2 cylinders seperately or should it
affect them both the same?
I believe it simply speeds the idle and the mixture is sorted by
the injection system. Is there some adjustment I've missed?
Is there something like an air / oil temperature sensor that could
be failing?
Cheers.
Ian.
