What do you think of mounting a stebel horn.....
...by strapping it around the front shock in the area below the shock spring and above the paralever arm??
Re: What do you think of mounting a stebel horn.....
That sounds like a rather bad idea to me. You'd be adding unsprung weight, and the horn has the potential to slide down the shock and foul the suspension, which could make for very unusual handling.
Some people have removed the carbon-canister and mounted a Stebel horn in it's place.
Don,
I know you've done that, but I don't want to as a "just-in-case" on future warranty claims. Do you have any other thoughts on possible mounting locations?
Who would taake a perfectly good charcoal cannister off of a motorcycle?
I'm hesitant to make any engine mods, i.e., removing the canister. What would I gain by doing so, other than a big place to mount a Stebel?
You wouldn't gain anything, except the mounting space you're looking for.
You would lose:
1. A tiny contribution to air pollution due to the evaporative emissions the canister helps control.
2. There is a chance that, if you had an engine problem, BMW could say, "Aha! You removed the canister. You're not covered by the warranty."
Yes, I know Magnuson-Moss says a company can't deny warranty coverage if the owner made a modification in a part of the product unrelated to the failure. But how do you define "unrelated"? My legal budget isn't large enough to find out, and I don't have enough confidence in BMW reliability to take the chance.
You would lose:
deilenberger wrote: Some people have removed the carbon-canister and mounted a Stebel horn in it's place.
Has anyone posted instructions for removing the canister and mounting the horn?
R1200R, R1200RT, R1200GSA, R100Mystic, R90S, R100RS, R100RS CFO
Well you could try this link, or try the Search feature.Ray R wrote:deilenberger wrote: Some people have removed the carbon-canister and mounted a Stebel horn in it's place.
viewtopic.php?f=20&t=14565&p=130082&hil ... rn#p130082
Michael
2007 R1200R Granite Grey
1979 Honda 750F
1979 Honda 750F
