I bought a 2002 used R1150R 6 months ago with 40,000miles on the clock.
The bike experieenced broken factory QDs previously and remedied by the local BMW Motorrad according to the previous owner.
When I decided to remove to tank a month ago I found this:
A direct connection between the tank and the fuel pressure regulator without QDs.
Close up
I have tried to pry/twist/pull the hose at the plastic regulator end (with the clamps loosen) but the hose didn’t budge even a bit after much patient and attempts. Further trying will only invite disaster, e.g. broken fuel pressure regulator plastic hose.
So I ordered a metal QDs set from beemerboneyard and got the kit a few days ago.
Now, I will need to pinch the hoses and cut them at the right places to put those new shiny QDs at the right place.
Would any kind soul grab a ruler and measure the length of the fuel hoses so that I can cut the hoses as per the factory length in order to get a QD placement as close as possible to the stock setup.
Thank you in advance
Cheers,
Phang
