Waterproof Side Case Alternative
GypsyRR
Centurionette!
Donating Member #: 254
Post by GypsyRR »
Has anyone tried these? Looking at the 11 photos that accompany the ad, how do you suppose it secures the bottom half of the bag to keep from flopping when on rough road. And do you think it would be universal - or at least fit a DR650 as well as an R1150R? Anyone?
http://www.aerostich.com/catalog/US/Low ... 19109.html
Kristi
05 Granite Grey
Biff's R
Donating Member #: 289
Re: Waterproof Side Case Alternative
Post by Biff's R »
The concern that I would have with any soft bags on the R, is clearance around the muffler. It looks like they strap on the rear footpeg bracket.
Look on advrider.com , and ibmwr.org you can find the hard cases for around $400(double the softbags, but worth it in the long run.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
GypsyRR
Centurionette!
Post by GypsyRR »
I have hard cases. I don't like them. Plus they just add weight. I'd sell them in a heartbeat if I had an alternative and this looked like a good one. They are advertised as low profile, i.e. they don't touch most mufflers. Besides, my can is gone on the BMW. woo hoo! The can on the DR has a heat shield covering it, and the rack sticks out enough that maybe the bag would still even clear the heat shield. It looks like there is some sort of shield on the back of the bag as well. I've just not seen enough bikes to know about this, or know enough about how various things attach to know if the system for attaching it is sort of universal or not.
Kristi
05 Granite Grey
MikeCam
Centurion Moderator!
Donating Member #: 100
Post by MikeCam »
Check these guys also... quality.
http://www.rka-luggage.com/A08%20BMW/BMWstartpage.html
And I'll buy your hard cases.
Airman
Post by Airman »
MikeCam wrote:Check these guys also... quality.
The RKA bags actually look pretty good don't they ?
mnnden
Post by mnnden »
I was up to Aerostich a while back and should have taken a closer look at those bags, I'm not positive but I think they require a "rear rack".( although I am sure something could be rigged to work). They look like great luggage, and Ortlieb is a good brand. I also prefer the soft luggage, my only requirement is that it be waterproof. I went to purchase their panners, I think they will work good on the KLR, and fit the BMW pretty good also, my only caution would be for persons with a leg inseam of over 30". Den
The Panners on the KLR (can you see them???)
and on the "R"
We all gave some,
Some gave all.
Anonymous
Ves
Post by Ves »
Looks like it has the necessary straps to get them fastened:
Hawkman
Post by Hawkman »
bought these bags last week... got them today... all the fasteners are correct and they fit well (high enough to clear the stock can) and securely (so far). My onliest issue is that the bags are long and either cover the turn signals or back up significantly into my rear end. I'm going on a short trip this weekend and will post my thoughts about performance in when I get back.
Cheers!
~Eric
'03 Silver R1150R
jaxter
Post by jaxter »
I'm using the FieldSheer bags:
http://www.fieldsheer.com/2008site/IE/p ... dleBag.htm
and I'm happy soooo far. I made a piece out of 1/4 " plastic stock to keep the left side bag off the exhause can and take it off when I get home from travel...
2004 R1150R - Silver
dmk
Post by dmk »
I've got a set of RKA's - I love em and think they really look great also. I was a little concerned about them clearing the tail pipe before I bought them - I actually use one long bungy cord and connect the bungy through the zippers on each side - does two things - keeps the zippers from opening up at high speed and gives the bags an inch or two lift so I don't worry about the clearance at all. I just got back from a 2800 mile trip - no problems at all with them. I'd send a pic, but can't figure out how to post a picture on this site :-k
Dan
04 Silver 1150R
