Turn Indicator Replacement DIN 72 601
Max Continuous
Post by Max Continuous »
I have been looking for a source for turn signal bulbs. The dealer only stocks amber or clear ones and I have mine wired as running lights through clear lenses. Therefore, I have ambers up front and reds on the back. I originally modified some red 1156 bulbs for the back but that is not optimal. Just wondering if anyone has done the same or has found a source where one can purchase the OEM bulb in red? :-k
Beemeridian
Donating Member #: 477
Re: Turn Indicator Replacement DIN 72 601
Post by Beemeridian »
77
taosports
Post by taosports »
Paul - I get mine here : http://www.lightlens.com/coloredbulbs.htm
You'll want the LB1156RJ - Red Japanese No Fade Bulb
Been buying my red bulbs through them for 4 years now. The bulbs last a long time - and I run them day and night.
Max Continuous
Thanks Tao!
I have been using red 1156 bulbs but had to file off one of the side pins to get it to fit in the housing. They also faded after awhile. I will try out your source for sure. That is exactly what I was looking for.
Thanks Again. =D>
