I have a small 12volt electric pump, which I am planning to use a pump in case of flat tires.
It has a cigarette lighter end, which I was going to cut off and attach small alligator clips, which when could be connected to the battery. Turn the bike on, and the pump works.
I believe could buy an adaptor to fit over the existing end, which would then fit inside the accessory plug on the bike, but hey that’s a lot more money.
My buddy mentioned that since my bike has a computer, and fancy electrical stuff, this might not be a good idea. This works on the old bikes.
Any suggestions??
Electric Pump to Battery
Michael
2007 R1200R Granite Grey
1979 Honda 750F
1979 Honda 750F
Re: Electric Pump to Battery
I have made my accessory plug a non canbus plug and have no issues with it in over a year. I tucked the stock one up under the seat because I didn't want to cut any wires and mounted the old style plug in it's place. I ran the wires to the battery.
Hi Michael,
After reading a lot about the CAN bus controlled accessory socket and its limitations (disconnected when the key is off) over at ADVrider, I connected a fused SAE pig-tail (compatible with my battery tender) directly to the battery. You could do the same for your pump. I also believe the accessory outlet is limited to 5A. Others here have installed a fuse block to run multiple accessories. Good luck and let us know how you do!
David
David
David Giannini
Santa Cruz, CA
'07 R1200R Black
'99 R1100SA Black
'93 900SS Red -Sold-
Santa Cruz, CA
'07 R1200R Black
'99 R1100SA Black
I use the Gerbing heated clothing pigtail connected directly to the battery, and have the adapter that allows the 2-prong accessory plug found on battery tenders and slime pumps to work with the same connector. The fuse is adequate to run the pump. One pigtail for everything.
Thanks for all your suggestions.
So it looks like a couple of options:
1) I can install an accessory plug right to the battery, with possibly a fuse within the line, which will run most 12 volt accessories
2) Connect the 12 volt electric pump directly to the battery.
Michael
1979 Honda 750F
1979 Honda 750F
Not possibly with a fuse in the line. Definitely with a fuse in the line.MJB wrote:Thanks for all your suggestions.
