Will 2004 R1150R Valve Covers fit a 2002 R1150R??
I like the way the 04 valve covers look on the twin spark. Will they fit on my 2002 1150R single spark?
Valve Covers
Hummmm
I don't think hat the valve covers will fit at all, I own an 02 RS (same covers) and have looked at the 04 twin spark. The covers may look the same, however if you were to put them on I think you will have oil all over since the head will have an opening where the second spark plug is supposed to be.
If you are talking about the spark plug wire covers I also think that they will not work, the old style ones have a 2 rubber support grommets that press against the head cover and a snap mechanism which holds the wire, in the twin spark these mechanism is similar but not the same in terms of where the grommits are etc.
Aloha!
EM
Aloha!
EM
R-1150 RS (ABS)
Starting to Like Power Assisted Brakes!
Honda XR 650 (Gone)
Honda XR 650 (Gone)
