dumb question
dumb question
Dumb question i know but where is the battery located on my 03 Rockster.
Many thanks - grief from you guys is expected, that goes without saying on such a dumb question from the UK !!
UK - Hampshire
Suzuki 600 Bandit - 00-04
Yamaha V-MAX 1200 04-08
Rockster 08 -
Rockster 08 -
Capt. Blackadder
Robert_winter_1000
Indeed, I agree with you. Maybe because they want to push lazy people to keep good contact with the dealer in place of self- reparation. B.T.W. be careful if you move the tank that you will not damage the oil radiator!MikeCam wrote:"...such a dumb question from the UK !!"
Not at all. It is really such a dumb location for the Germans to use.
Robert
# 195
Pulling he tank is covered in the owners manual, if you've got one. But the detail is a bit limited.
The first time I pulled my tank I also used this link:
http://home.mindspring.com/~jabrooks/te ... emoval.htm
While not a Rockster, this may be of use.
And you may want to read up on how fragile the quick connects are.
Good luck.
Good luck.
- Bill #438, Lifetime
The late 2004 (2003 in Europe) and later R1150R has a positive post, right on the starter cover. If you don't have one, you can easily add it yourself with parts from the dealer (I did this).ROBOX wrote:Thanks for all your help guys. Just wanted to know if I need to charge the battery but as I have been told there is a positve post I can use.
Thanks folks
Here's a pic of mine. the lug is just in front of the accessory port:
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
I think it was a mid-year addition to the '03/'04 models. Like I said, the dealer has the parts needed to add one. All you'll need to do is drill a hole through the plastic starter cover and bolt it onto the starter solenoid. The parts are inexpensive (under $10(US)).
Mine ('04) doesn't have one, but my previous two (a '53 and an '04) did.ROBOX wrote:Thanks guys, I don't have a jump-starting lug, or the accessory socket. Do you know if European models, mines an 03 Rockster, are different to those in the USA, or are these addtional to orig spec from BMW ?
Just random off the line I think....
allanj255
The wiring is there, tucked behind the cover to fit an accessorie socket, just get a socket from the dealer, remove the blanking plug from the starter cover and plug in. I guess that BMW were just penny pinching on UK models as they went to the trouble of fitting the wires and saved a few quid by not fitting the socket.
I got a socket off eBay for £2-00 and just changed the terminals on the end of the wires as they were different from the BMW connections -But the socket was a lot cheaper than a BMW one. I use a battery tender that plugs in to the socket to keep my battery good.
Allan
2003 R1150R Twin Spark, (Black - the fastest colour)
