does anybody know for sure if the rockster has the same big gap between 5th and 6th that the 1150 R has? i did a quick search here and couldnt find anythin anywhere but i coulda missed it!
cheers
rockster/R1150R gearing question
- cworley5150
- Location: Princeton (not NJ but in the other armpit) WV
I'm not sure if it is a 100% thing, but as far as I know Rocksters had a lower sixth gear than the Roadsters. My 5th and 6th are only about 500-700 rpm difference at the same speed. Or another way to say is, 3500rpm in 5th is about 55mph. 3500rpm in 6th is about 65mph. Personally I would like the "overdrive" 6th better. Things get a bit frantic on the highway crusing at 85mph or so. But still not a big deal.
No matter where you go, there you are.
Boxers Rule! Umm. . . the bikes, not the underwear.
bloke
It is easy to check.
First look at the differential right behind the vent and you will find a number there, something like, 31/11 = 2.82 that is the final ratio.
That ratio is the "low" (more rpms) and should give you ~ 70 mph at 3500 rpms. The "high" as cworley5150 aluded to should give you ~ 65 mph at 3500 rpms.
I do believe the Roadsters came with the "low" ratio, you can verify with your dealer.
