I think my oil filler cap is leaking...
Here is the story:
I topped off about .3 quarts yesterday, and I cleaned the cap and everything around it - it was spotless.
I was riding today and I looked down and noticed that oil had trickled down the front of the valve cover, and the cap was oily.
I assume the cap just needs a new o-ring or something simliar.
Has this happened to anyone else? I only have 8,200 miles.
- Anthony
- Anthony
Yeah, do a search, there's threads on this. I bought all the parts, replaced them, and it hasn't leaked since. You need the piece the goes into the valve cover, the o-ring that goes with it, a new cap, and new cap o-ring. I think all the parts together are less than $10.00.
Before you go too far, be sure that all the surfaces are clean when you put it back on. I had some weeping at the oil cap and members of this board advised me to clean with a rag before screwing it back in. I did and the weeping stopped, never to return.
If that doesn't work, then replacement parts might be in order.
Vann - Lifer No. 295
I had cleaned the cap and the filler "neck" after I topped off.wncbmw wrote:Before you go too far, be sure that all the surfaces are clean when you put it back on. I had some weeping at the oil cap and members of this board advised me to clean with a rag before screwing it back in. I did and the weeping stopped, never to return.
Here are the parts that I found:
11 14 7 659 578 filler pipe 1 $4.50
11 14 1 340 901 o-ring 1 $1.50
11 14 1 340 900 oil cover lid 1 $3.10
11 14 1 340 902 o-ring (18X4) 1 $2.00
Same here. Replaced o-ring in cap and slowed it down to almost nothing for several months, then leaking returned and I replaced o-ring around filler pipe and no leaks since (over 1 year ago). Note: the Filler pipe came out easily with the valve cover off (during a valve adjustment) but I couldn't remove it with my finger through the hole with the cover on, it had to be pushed out from inside the valve cover. There have been some threads about this in the past.
ADIOS!
ADIOS!
Capt. Blackadder
Or, you could get Viton replacement O-rings from somewhere like McMaster-Carr. That ought to stop the leak for good.rdsmith3 wrote:I have replaced the whole assembly twice, and it stops the leaking each time. However, eventually things loosen up and the leaking returns. I guess I will have to make this an annual maintenance task.
- geothepencil
Not sure about the locking oil cap but the Moto Techniques http://www.moto-techniques.com/bmw.htm cap definately cures the problem permanently. And even though it doesn't lock, since it requires a hex key to remove, it offers a fair degree of protection from your average neer-do-well. The only draw back is the price (~$60 with shipping) but it's a one-time purchase.Will the locking oil cap fix this problem
Charlie
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
Life member 365
Do you know that for a fact? We are dealing with cheap plastic parts that do not fit well, and that continually expand and contract from heating/cooling (and probably expand/contract in a different way than the metal). It is not a great design. Is it true that a different type of O ring will overcome the problems and create a better seal?Capt. Blackadder wrote:Or, you could get Viton replacement O-rings from somewhere like McMaster-Carr. That ought to stop the leak for good.rdsmith3 wrote:I have replaced the whole assembly twice, and it stops the leaking each time. However, eventually things loosen up and the leaking returns. I guess I will have to make this an annual maintenance task.
One of those fancy metal caps might be the cure, but I am reluctant to spend $60 for an oil cap.
Bob
2002 Atlanta Blue
Lifetime Member #74
2002 Atlanta Blue
Lifetime Member #74
I very much doubt that replacing what is probably a Buna-N O-ring with Viton will be a permanent fix for the problem. As rdsmith notes, the root of the problem is the design and materials of the plug assembly. Not only does the plastic oil plug not expand at the same rate as the Mg valve cover, it also becomes more flexible when hot which has to affect its power to effectively seal things.
The metal replacements are pricey but it's a one-time expense. For 60 bucks, you not only fix the problem for good, you also get the peace of mind that comes with knowing that you will not get stuck on the road due to an oil plug failure and that a malevolent passer-by can't easily remove the plug. BTW, the MotoTechniques plug comes with Viton O-rings in place.
Seemed like good value for money to me, which is why I changed things out before I had a problem.
Charlie
Charlie
'03 R1150R
Life member 365
Life member 365
Capt. Blackadder
No, I don't know that for a solid fact, hence the "ought to" part of my reply. However, the Viton O-ring solution has worked perfectly for my cam chain tunnel covers for almost five years now, and I have no reason to think that the same won't apply for the oil fill cap.
ProductUser
I am very careful not to spill any oil around the plastic assembly. If I do, I pop it off, clean it, reinstall.rdsmith3 wrote:I have replaced the whole assembly twice, and it stops the leaking each time. However, eventually things loosen up and the leaking returns. I guess I will have to make this an annual maintenance task.
Once I'm done adding oil, I will clean the fill cap, fill cap o-ring, the assembly the receives the fill cap o-ring with a rag saturated with soapy water. This removes all of the oily residue. I've been using the same o-ring and assembly for over 30k miles.
ProductUser
