Tail Light remains on after hard breaking or prolonged trips
paithorn
Post by paithorn »
My 02 R1150R's tail light will remains on throughout after a hard breaking or prolonged trip. After turning ignition to off and on again, the light will be reset.
I have complained abt this to my dealer during servicing and it seemed that the fault cannot be duplicated. Anyone with the same prob and solutions?
maduko
Donating Member #: 735
Reset?
Post by maduko »
With or w/o ABS?
sjbmw
Moderator
Donating Member #: 263
Post by sjbmw »
I have a non-ABS, and my bike did that after I got it repaired from my crash.
The front brake lever was replaced, and there was an adjustment that had to be made.
paithorn
Post by paithorn »
Mine's ABS....replacing Brake levers? Hmm............
baltm604
Post by baltm604 »
it turned out to be the micro switch that is in the front brake lever. A cheap part. If it happens to you again, pull the little cover under the brake lever and pull the switch off. mine just needed to be adjusted a little bit and when I put it all back together it was fine.
paithorn
Post by paithorn »
thanks mate, I will try it out...
