I previously decided not to change the QD's unless I had a problem. Just in case, I carry a spare along with FI clamps and a straight brass connector for emergencies. Even though I was home, I decided to pretend I was out in the middle of nowhere and change the QD with just the tools on my bike. I'm not sure I could have done it. Getting the old hose clamps off was nearly impossible. I ended up cutting them with a Dremel cutting wheel. I might have been able to cut them with diagonal cutters, but didn't have a pair on the bike. Anyway, I just replace the male piece, but replaced all the crimp-on clamps with regular FI hose clamps.
For those who have never seen a broken quick disconnect, you can note the picture below. At the top is a normal QD with male and female parts. Second is the male part with the "male part" broken off. Humm. Last is a 5/16 inch barbed brass connector from Home Depot which costs about $1.50. I haven't decided if I will replace the stock QD's with metal ones or just use the brass connector. I'm leaning towards just the simple brass connector after I buy some cheap hose clamps.
