I got my bike back today and my neighbor helped me put the Givi on to the mount. Then I took it out to see if it made a difference in handling and noticed a problem with it. The bottom of the mount does not sit flush with the BMW rack and so it is bouncing against the rack as I ride - the exposed bolts are scratching the rack. Is there a fix for this?
The picture shows where the bolts closest to the pillion are scratching the rack.
Kristi
Kristi wrote:I got my bike back today and my neighbor helped me put the Givi on to the mount. Then I took it out to see if it made a difference in handling and noticed a problem with it. The bottom of the mount does not sit flush with the BMW rack and so it is bouncing against the rack as I ride - the exposed bolts are scratching the rack. Is there a fix for this?
Kristi
It doesn't look like you're using the right mount, Kristi. Try the 2002-04 BMW K1200RS soft bag black plate with enclosed lock. It snaps onto the Roadster back rack. I used one with the soft bag and the hard bag. (I just may have one around, somewhere).
Thanks for your reply. However, that is the mount I'm using. I got it from TonyT607. K
Okaaaay! I took a closer look at your picture and a look at the plate I have---yep, you're right----plates are the same. The rear rack for your bike should be the same as on my 2005 R1150R.
So, seems the problem is the hardware attaching the plate to the Givi box. Try using shorter bolts??
My top box is a Kappa, which is interchangeable with Givi AFAIK.
BMW rack was removed so I have 4 empty holes. Long mounting arms then pick up on pannier mounts and a special top box pad is fitted.
Must try a photograph later.
