Rattling jingling sound lower left side when cold
Soliton
Post by Soliton »
R1150r 2002 - new secondhand bike.
Imagine getting a length of kids bicycle chain and pulling it across the rounded shaft of a scrwedriver. A clattering jingly sound, high pitched and almost musical in an ominous "something terrible is gonna happen" way.
When the engine is cold it is loud and noticeable, as it gets hotter it is still noticeable but not as loud.
I want to fix it before it creates another problem but i don't want to take a bath at the local BMW dealership. LHS cam chain tensioner was the first thing I thought of but it appears to be the new one not the old one (doesn't necessarily rule it out I suppose.)
Any ideas guys/gals?
Rs,
Sol
R4R&R
Donating Member #: 293
Re: Rattling jingling sound lower left side when cold
Post by R4R&R »
I'm thinking a loose valve or the cam chain tensioner?
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
kirby
Donating Member #: 3
Post by kirby »
kirby
Post by kirby »
As r4r7r posted and also rocker arm float.
Don't know how many miles you have but possible, although I'd say cam chain tensioner is best bet. May need to up grade to the new one.
If the tensioner, don't run it long without replacing with up graded one.
Sunbeemer
Donating Member #: 593
Post by Sunbeemer »
Sure sounds like a cam chain tensioner noise to me. It think the new ones have a 15mm head vs. 17mm for the original, if memory serves...
Soliton wrote:Imagine getting a length of kids bicycle chain and pulling it across the rounded shaft of a scrwedriver. A clattering jingly sound, high pitched and almost musical in an ominous "something terrible is gonna happen" way.
This is a long shot, but your sound description fits it perfectly. I would remove that left valve cover to check things out.
Peek down the area between the camchain lengths, into the crankcase. You should see a nice smooth gradual bowed in the middle arc of the upper chain run. If you see a sharp bend or a drop-off, the plastic chain guide is broken, generating the bicycle chain pulled across the rounded shaft of a screwdriver sound. This can happen if a malfunctioning chain tensioner has been used for way too long and the wildly whipping around chain just beat the chain guide to death. Another chain guide breaker event could happen when the (VERY TIGHT!) cam sprocket bolt is removed for cylinder head removal. The curved upper chain run is under so much tension from the powerful loosening force of a big half inch drive ratchet turning the still tight sprocket bolt that the normally bowed tensioner guide is forced to straighten out, crushing it upward to flatness.
That was the long shot and I hope it has not occurred. Maybe you just have chain and guide wear that a weak or worn chain tensioner just cannot silence.
Soliton
Post by Soliton »
Thanks guys,
Next stop... Chain tensioner check. I replaced it on the old bike. I will swap them out and see if it makes a difference.
Rs,
Sol
sykospain
Post by sykospain »
The famous Chris Harris had a coupla cam chain vids on the Toob - one of which explores the smashed guide-rail scenario.
Watching that one fills me with dread cos you have to take the crankcase apart....
AL in s.e. Spain
