Auxillary light mounts-Update!
Hey guys and gals! So I had mentioned that I am trying to add a little more light to the front of the bike, as I know many of you have. I read as much as I can about mounting options and it looks like lots of folks go with the luma links which look great and are about as functional as it gets. And while I still may go that route, I was wondering what other options you all have come up with that are more, how shall we say, budget friendly.
I do have a fabriactor locally that said he could "come up with something" but he wants just as much as the luma links would be.
Found tons of stuff for the GS but no a lot for out beloved R12s.
Short of zip ties and duct tape, I would love to hear what you folks have come up with!
Thanks!
Thanks!
Re: Auxillary light mounts
Their must be hundreds of pictures and posts on this list about auxillary lights and their mounts. Did you try to SEARCH it.
2011 Sportster
2011 Sportster
I did do a search and most of the threads wind up talking more about the actual lights rather than the mounts (which was very helpful in it's own right). I read up on Don's configuration and i think that is something that would work for me. But I guess I should have been more specific in my original post. I'm really looking for fork mounts rather than crash bars, calipers etc. While these are all great ideas, I like to have the lights a bit more headlight level or slightly below making a triangular pattern.
Like I said, if luma links are the only solution, then that might be the best route.
- websterize
Check out Skene's Photon Blasters, noting his gallery page. Lots of mounting options.
I went with the Clearwater Glenda lights on a caliper mount. I'm happy with that set-up. I'll see if I can find the pdf and PM you.
- BLAIR1200R
I don't know how much the LumaLink brackets cost (couldn't find a price sheet), but Wunderlich sells lights/brackets combo for $299. Not inexpensive, for sure, but one thing I liked about these was the mounting location.I was wondering what other options you all have come up with that are more, how shall we say, budget friendly.
http://www.wunderlichamerica.com/mm5/me ... t_offset=2
I say this because I like the lines of the R1200R, so I'll try to blend form & function and still get some additional lighting.
bLaIr1200R
2012 Grey Matt R1200R
"The universe rings true wherever you fairly test it."
Those Wunderlich lights might actually be an option. Will give them a call and report back. Thanks!!!!
Here is my setup with the Clearwater Kristas on Lumalink mounts:
MSF #127350 NAUI #36288
2011 RT
2011 RT
[quote="ka5ysy"]Here is my setup with the Clearwater Kristas on Lumalink mounts
Any issues with the CAN BUS system?
Roder wrote:ka5ysy wrote:Here is my setup with the Clearwater Kristas on Lumalink mounts
No, because the power to all the accessories I have added are through a switched fuse box and then directly to the battery. The only connection to a canbus line is to the headlight circuit for the sensing voltage to the fuse box switching.
2011 RT
2011 RT
I drilled through my Motech bars to mount a set of Denali D2's and avoided paying for an additional mount kit. Worked out fine and the location suits me well. I posted a thread here on the install search denali D2...
Re: Auxillary light mounts-Update!
So I went today to see someone in my area today who is know for his talents in metal fabricating to see if he can make some custom light mounts for my bike and here is what we unearthed. If you have a 2011 and now, the 2012, most, if not all, aftermarket fork mounts will likely not work due to the fact that the '11s and '12s have forks that taper. The diameter is smaller at the top then at the bottom where the previous years' forks are just tubular with the same diameter throughout. In person, it is really obvious.
So he took some measurements with some tools that looked like something a NASA engineer might use and said that he would let me know in a few days what he comes up with. Said he wants to make a dummy model first just to see if he's got something to work with. Had no idea light mounts would be this much fun to find!
Anyway, I will keep anyone who is interested posted. As soon as he comes up with something, I will post.
This is the first bike I've ever bought brand spanking new. Guess you've got a wait a while for the aftermarkets to catch up.
ka5ysy,ka5ysy wrote:Here is my setup with the Clearwater Kristas on Lumalink mounts:
What size shield do you have in this pic? Thanks.
2012 R1200R | Grey Matt | Safety Pkg | TPMS | On Board Computer | Luggage Rack | VStream Shield
The 2007-2010 for sliders also are tapered.. Not a problem with the Lumalink brackets - they are a variable diameter and adjust for the taper. The reason I know this - I worked very closely with James Gordy (RIP) in designing them to fit the R12R.. and sent multiple measurements to him. The early sliders not only are tapered they are oval in cross-section (the new ones are round..)ddepr1217 wrote:So I went today to see someone in my area today who is know for his talents in metal fabricating to see if he can make some custom light mounts for my bike and here is what we unearthed. If you have a 2011 and now, the 2012, most, if not all, aftermarket fork mounts will likely not work due to the fact that the '11s and '12s have forks that taper. The diameter is smaller at the top then at the bottom where the previous years' forks are just tubular with the same diameter throughout. In person, it is really obvious.
You might talk to his son Brian Gordy who is continuing the business. I'm sure if he hasn't already designed a mount to fit, he can and will if you can give him the dimensions.
