gearshift lever
gearshift lever
Got a question...
Is the gearshift lever on our bike adjustable; up and down? It looks like it is but I don't see anything about it my Clymer manual and I don't want to mess anything up. I have a new pair of boots and it would be nice to adjust it up a bit.
Dwayne
Dwayne
'04 R1150R Black
Re: gearshift lever
22
Re: gearshift lever
If adjusting the lever does not fix the problem, ride round town for an hour, you will adapt to the new boots. Honest
Rod
Apple Macintosh
Apple Macintosh
Re: gearshift lever
That's funny. Today was my first ride with new boots and I was planning to do the adjustment after I had ridden a ways but by the time I got home 150 miles later, it did not seem so necessary!If adjusting the lever does not fix the problem, ride round town for an hour, you will adapt to the new boots. Honest
Vann - Lifer No. 295
Re: gearshift lever
Hey Dave, it looks like realoem.com doesn't allow hot-linking . . . . we see an empty white placeholder box where the pic should be. Here's my descriptive pic showing how the retainer clip secures the ball joints on the shifter link:
http://i142.photobucket.com/albums/r87/ ... ifter1.jpg
Compared to the typical shifting linkage on the average bike, the stock BMW stuff is very durable and well designed. You just need to know the simple secrets to it's disassembly or adjustment.
After a gazillion shifts in over 6o K miles on my bike the linkage is still pretty tight.
Re: gearshift lever
I needed to replace those little rubber bushings on my gearshift linkage, but was stumped about how to remove the retainer clips. Then I remembered a post by CycleRob. A search of the forum "gearshift CycleRob" brought this right up. QED and about 15 min later I was done! Thanks r1150r.net and thanks CycleRob! Life is good.
+1!
+1!
-duckdave
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
Re: gearshift lever
Those little clips are tricky to undo unless you know how it is done. I adjusted my lever when I got new Altberg boots a few years ago and it was well worth while.
Re: gearshift lever
I need to remove the peg extenders that were put on my bike by the prior owner. Getting the shifter bolt out is TOUGH! Is that because of the lock-tite? Do I really need to heat with a heating gun? It is hard to get enough torque with the hex-wrench given the position of that bolt.
Steve
Steve
- my brother-in-law's brother
Re: gearshift lever
22
2015 Honda PCX150
2015 Honda PCX150
