Luggage rack install
darth_rockster
Post by darth_rockster »
Probably one of the easist parts to install but I had a question I was hoping someone could help with.
I had the system case mounts (aka those rails with the handles) installed at the dealer when i bought the bike and they must have put these plugs into the holes that the luggage rack screws go into.
The plugs are part # 46547655724 on the parts fiche I believe.
Anyone know of an easy to remove them and keep them intact?
I tried pushing but they are in there pretty good.
Or do i have to drill them first maybe? :(
Thanks!
DR
2004 BMW R1150R Rockster - Edition 80 - #110
RUSOR80!
Post by DJ Downunder »
Put down the drill and step away from the bike..... :D
If it's the little round plugs they should pop out with a small screw driver..mine did.
If it's what looks like plugs..on the inside of the rails..where the case tab pushes against..they are not plugs.
Good luck.
DJ
darth_rockster
yeah thanks for the tip DJ.
them round ones popped right off with a small screwdriver from the inside.
Actually they split in half and popped off easily from each side.
i had thought they were 1 piece as in the parts fiche and was pushing with my thumb :oops: i be luggage racking in no time.
RUSOR80!
