Quick Disconnects (again)
- Dr. Strangelove
- Double Lifer
Dr. Strangelove,I feel justified carrying the two straight brass connectors in my tool kit.
I picked up some straight brass connectors prior to the ride to Wisconsin. I ended up getting both 1/4 and 5/16 inch because I wasn't sure which to buy. At least they were cheap. Isn't it 5/16 inch?
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
Ogden, Utah
2002 R1150RT
2004 R 1150GS
- Dr. Strangelove
- Double Lifer
You need to pinch the return hose, which is unrestricted and will flow until the fuel in the tank drops to the level of the hose. The pump will block the fuel in the other line, though the fuel between the QD and the pump will run out.Is the hose pinch to prevent the flow of fuel? I thought it would not flow unless the pump was running, am I mistaken there?
While I appreciate the simplicity of replacing the QDs with a straight pipe, I have to say that the problems cited in this thread all seem to be related to the design of the LittleParts QD. I have not exerienced any problems with the Omegas and the standard Buna-N O-ring.
Charlie
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
Life member 365
Since I take my tank off at most twice a year, there is no need to gamble with QD's, no matter the manufacturer. Most other tasks (e.g., front shock R&R, running wires for powered tank bag...etc.) can be accomplished by raising the tank without removing the fuel lines.
The last thing I want to happen while on the road is the possibility of having fuel dripping on a hot exhaust, not to mention the discoloration it causes on the tranny and other related bits.
That's my $.02
ProductUser
That's my $.02
ProductUser
DJ:DJ Downunder wrote:Good question....I'm looking for some straight pieces of tube to replace the dis-connects..but I'm looking for some tubes with those barbs on each end.Has anyone using straight copper tubing had an issue with leaks or is anyone worried about it coming apart? The connectors all have "barbed" ends to help hold them in the fuel line.
I'm sure they're out there..I have not really started looking yet..I'll let you know if I find any....There's a lot of pressure in those lines.
Some others here have just used straight tubes without any problems...but the barbed ones would give me better peace of mind.
DJ
I've planned on the hose-pinchers in my kit and straight copper pipes for a long while. I posted about it probably a year ago - procrastination is my dominant feature.
I never gave a thought to the pipe ends. But....
As an alternate how about a pipe flaring tool. It's kind of a C-clamp looking device that allows you to force a small cone shaped piece into the end of the copper tubing. Makes a small flare in the tube (like a trumpet end, but not nearly so dramatic).
http://www.baconsdozen.co.uk/motorhome/flaring.htm
Then the hose would be clamped and, to come off the hose would have to pull the flared pipe though the clamp. I have one of the pipe flare somewhere in my stacks of tools used once in a blue moon.
Just a thought.
- Bill #438, Lifetime
I see that Omega offers their fitting with Viton:boxermania wrote: Most vehicles fuel systems are equipped with Viton 0-rings, Buna N is a second choice on use.......Viton and Oxygenated Fuels are not a good choice.....but I'll talk more about that in another post.
FT-LCD170-05-VITON
But, is Viton not the right choice for gasoline in the USA?
Reid
I ordered Omegas which were marked "out of stock for one week". However, they sent a notice the next day that they had been shipped to me, complete with tracking number. Also, I ordered them with Viton o-rings.
I had an OEM quick disconnect on my 2004 1150R fail last week on a ride. I'm changing them on both bikes. Why worry about it.
I'm curious. Are the metal Omega quick disconnects compatible with the plastic OEM QD's? The reason I ask, I noted my mechanic has a short piece of hose with a plastic quick disconnect on it. When he has to remove a fuel tank, he connects the short hose to the fuel line and quickly drains the fuel from the tank into a gas can. Good idea if the connectors are compatible.
Al
Ogden, Utah
2002 R1150RT
2004 R 1150GS
Ogden, Utah
2002 R1150RT
2004 R 1150GS
... a topic that won't die.
My original post was over a year ago.
About the o-rings. I believe I still have the viton ones installed. Over the past year I have removed the tank 3 or 4 times. Each time I inspected the o-rings, and they showed no sign of wear or deterioration. The connectors slid back together with no problems, and no leaks.
jb
jb
Re: Quick Disconnects (again)
more miles to go . . . .
See you down the road
2004 R1150R Piedmont Red
Member #509
Member #509
Heads up on the Omega Chrome Plated Brass Shutoffs. I checked with the Technical folks at Omega and to get the Viton Gas Resistant O-Rings the Part numbers for the 5/16 Straight line Dual Fuel QD's with the Shutoffs for your BMW are as follows:
Quantity Model Number Price Item Total
2 FT-LCD220-05-FKM $16.00 $32.00
2 FT-LCD170-05-FKM $26.00 $52.00
Regards;
Paul
web site http://www.omega.com/index.html
Regards;
Paul
The power of accurate observation is frequently called cynicism by those who don’t have it.
Try Jiffy Tite.. No viton o-ring to replace.. contains a stainless ball only..
Here's some info from the web site.. And by the way My "Dealer" broke one of my stock QD's last month when bike was serviced.. Replaced ONE ONLY qd with the metal type.. I had.. & still have my Jiffy Tite's on the bench waiting for install.
Jiffy-tite's revolutionary Quick Connect Fluid Fittings provide unsurpassed performance under extreme conditions. Made of lightweight, 6061-T6 aluminum, brass valves, and stainless steel ball bearings, they are corrosion resistant for extra long life. Jiffy-tite's unique, high-flow valve technology in the plug and socket assembly automatically interrupts the flow of fluid when disconnected to protect against hazardous gas leaks. Tested and proven to have a 100% leak proof seal, even at 200 psi. The Jiffy-tite fittings have no serviceable o-rings to replace.
I'm hopeful these work well as I bought a set, soon to be installed.......ArtieMS wrote:http://www.beemerboneyard.com/cpcqkdiscon.html
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
2008 Suzuki Bandit 1250
2013 BMW GS 650 Sertao
1975 Norton 850
2002 BMW R1150R
