I have done some more reading about the prolaser III.
I don't have access to the manual or the specifications, but from the operations steps I infer that the laser gun emits not just 2 pulses but a series of pulses. The gun computes the speed based on consecutive measurements. When the computed speed stays stable within a given (reasonable) range, the gun emits a buzz indicating to the operator that an accurate/stable measurement is possible. The operator then presses the button to record the speed. If the buzz stops during this reading the data should be considered false.
Per the instructions, the whole operation should take about 3 sec.
Ouch! That's gonna hurt with cameras. CCD cameras are very accurate (fast snapshots), and the processing of images is good enough to make pixel-to-pixel comparisons. The processing uses fuzy logic algorithms, which is already used to stabilize images even in some commercially available electronic cameras.budH wrote:Unfortunately, this will all be a moot point in the future when common use of newer speed measurement technology is adopted - such as http://www.its.washington.edu/pubs/Auto ... IV05-2.pdf
