Removing front wheel confusion!
I am ready to replace my front tire and after watching a few You Tube videos and even a few documents on oil heads they all indicate that the speedometer cable needs to be removed from the front. Maybe I need new glasses or better lighting in my garage but I can’t seem to find where the speedometer cable attaches to my front wheel. I have watched 3 on-line videos and they don’t look anything like my AMAZING Rockster.
Re: Removing front wheel confusion!
You can't see one becouse it doesn't have one....Rocksters use a electronic sensor on the rear bevel drive.
Great! (Boy do I feel silly!!) It’s seems it’s a pretty straight forward procedure. I always took my K75 to a local shop for tires but this time I wanted to do it myself. I have read a few articles where people don’t remove the brake system. They simply remove the wheel while warning about damaging the ABS sensor. I am always open to best possible advice.
Thanks Tricktree!
G!l
Thanks Tricktree!
G!l
Hi Guys
I need to replace the discs on my 500SL pantah, and therefore need to remove the front wheel.
Is it as easy as it looks and I just undo the two nuts by locking one and turning the other.
Any gotchas or other advice.
Thanks Guys
Thanks Guys
One question...what is a pantah?
mike Mojave CA
'04 ROCKSTER
'04 ROCKSTER
MichaelCew wrote:Hi Guys
Thanks Guys
kirby wrote:One question...what is a pantah?
Ducati L-twin.
500SL is rare, got any photos?
I had a 600TL for a few years - LOVELY bike to ride, (if a bit ugly).
Make sure you brace the bike well - the centre stand is a bit narrow.
I'm trying to remember how to do the front wheel now. Will post more if I remember, but I seem to remember it's fairly normal.
Whatever - it's always easier to remove the calipers, otherwise you stand a good chance of damaging the discs when you try to replace the wheel.
