deilenberger wrote:I got to try them last night on the way home from our local club meeting.
Marvelous! The pattern was about perfect, filling in and extending the reach of the stock headlight, while not adding additional light close to the motorcycle. They are bright and well focused.
The only thing I'm thinking on changing now is where I have the on/off switch located. It's fine - falls readily to thumb, but it also hits the tank bag when doing backing up tight turns - like backing the bike into my garage. That ends up switching the light on and off when it doesn't have to be. I means either a smaller tank bag (probably would actually be a good thing..) or a different location for the switch. But for now - it's fine and I'm going to take a break from messing with it for a bit.
Any questions - comments - more then welcome.
BTW - the MotoBozzo lights are for sale - $100 with a custom wiring harness - if you need daytime conspicuity lights they are just fine for that.
Don, can you update us as to how these lights are holding up?
