Took out my 2002 R1150R after a severe winter and noticed that the right side hand grip has a horizontal tear about 3 inches long and about 1/8 inch wide. The heating still works and there is nothing that seems to be wrong except the tear.
Any suggestions from the wise folks on the forum ?
Sunil
Cracked handgrip
Re: Cracked handgrip
Order new rubber grips from ebay, peel of the old ones with a utiility knife, put some towels on the steer & lever/button housing, spray the handgrip & the inside of the new rubber grips with glue, slide it over while everything is still wet. You have some time to position the new grips before the glue starts drying. Chore takes about 20 minutes, can't really mess it up. Just make sure you do not damage the heating loom.
Edit: replaced the rubber grips on multiple bikes in above manner.
OR put these on... no glue to contend with and better shock absorption
Easy on, no gluing
http://www.shop.originalbeemerbuddies.c ... -AB-SS.htm
I really like my pair
Rags
Easy on, no gluing
Rags
Thanks folks.
I would have liked to replace the grip by cutting it away but am vary of destroying the heating loom. I will watch out for further degradation and till then I will use an over grip as suggested.
I appreciate your guidance.
Sunil
Sunil
When I did my grips they are only really attached at the bar ends. I was able to carefully cut the end of the grip and I just blew air into them and got them off. Even if you accidentally cut the heater wires its a quick solder fix to repair it, its just a small wire wound around the bar covered with brown paper.
