Y Pipe
Bruno
Y Pipe
Post by Bruno »
I ride a 2005 R1150R and am cosidering going to a Y pipe, Will this boost bike performance and do I need to adjust fuel system
Ol' Jeffers
Re: Y Pipe
Post by Ol' Jeffers »
Yes, a little and No.
I have a similar set-up but with a brilliantly modified muffler
internal carried out by a highly skilled member here.
So now the bike sounds like a bike and has slightly better
acceleration and is a little more frugal on fuel. The system
was able to adequately compensate for the changes with
no adjustment being required. HTH :)
OJ........everybody's pal!!
Beemeridian
Donating Member #: 477
Re: Y Pipe
Post by Beemeridian »
15
2015 Honda PCX150
Bruno
Re: Y Pipe
Post by Bruno »
Thanks guys, think I'll stick with what I got
ron prior
Re: Y Pipe
Post by ron prior »
Bruno wrote:Thanks guys, think I'll stick with what I got
I just put on a "Y" pipe and a Remus muffler. Not sure yet if I like it. I'm doing about a 500 mile trip this weekend, that will tell the tail. [If] I do not?...I'll switch back to stock.
ron prior
Re: Y Pipe
Post by ron prior »
Well, I did my trip, 440 miles,..and I'm still not sure? It sounds good, not loud,..looks nice , but!..the motorcycle feels like it has a buzz in it , it never had?, right at about 3000-3200 rpm. You know ? like sound [pulse waves] will do.
It's very slight. Anyone else noticed anything like that?...with an aftermarket set up?
Beemeridian
Re: Y Pipe
11
2015 Honda PCX150
ron prior
Re: Y Pipe
Post by ron prior »
Beemeridian wrote:
ron prior wrote:...the motorcycle feels like it has a buzz in it , it never had?, right at about 3000-3200 rpm. You know ? like sound [pulse waves] will do.
See my post above.
Well POOP!...did you try the "Y" pipe, & stock muffler? As I said, I'm not into noise?....but would like to have the other advantages, weight loss...and just having it 'un-corked' so-to-speak.
The 'buzz' isn't really bad...but wasn't there before, and I'm wondering if on a long trip, [several long days strung together] if it might get to me?
Ron
Beemeridian
Re: Y Pipe
10
2015 Honda PCX150
ron prior
Re: Y Pipe
Post by ron prior »
Beemeridian wrote:[quote="ron prior"Well POOP!...did you try the "Y" pipe, & stock muffler?Ron
Yes.[/quote]
What was that like?
Beemeridian
Re: Y Pipe
9
2015 Honda PCX150
ROXTR
Re: Y Pipe
Post by ROXTR »
I also have a resonance around 3100 RPM on my Rock, but my exhaust is fully uncorked, Two Brothers y-pipe with a Leo Vince slip-on. My cure for the problem, don't let it sit at 3100 RPM. I usually keep my cruising RPMs around 4k and have no annoying resonance by doing that
Rockster
Gimbel | Sargent | AFXIED | LeoVince | BoxerPerformance | EBC | Metzeler | RS Ducts | UNI | Bitubo
ron prior
Re: Y Pipe
Post by ron prior »
ROXTR wrote:I also have a resonance around 3100 RPM on my Rock, but my exhaust is fully uncorked, Two Brothers y-pipe with a Leo Vince slip-on. My cure for the problem, don't let it sit at 3100 RPM. I usually keep my cruising RPMs around 4k and have no annoying resonance by doing that
LOL!!...you don't live in,.. or travel much in, Ohio. 31-3200 6th gear is just above the speed limit,...and my state cuts no slack....too no body.... 8-[
ROXTR
Re: Y Pipe
Post by ROXTR »
Downshift to 5th? :-k
Rockster
