Frame brace?
Frame brace?
I was at a shop the other day and they had a R1100r with these Touratech braces on the frame where it meets the tranny. The bike had a big ugly weld on the right side where it had broke. My question is this...is this a common problem? The braces are still available so should I get a set ? Thanks
Re: Frame brace?
Hi,
as per my knowledge this used to be primarily a problem with the GS models than with the R models. Hence I would not worry much if you have the R ...
Brgds
Oliver
Brgds
Oliver
