Picked up a set of used system cases for my Roadster.
How do I remove the lock cylinders from the cases?
Not a big deal, but I'd rather need just the one key.
Thanks, Ron
System case locks
Re: System case locks
Search & Google:
viewtopic.php?f=2&t=20179&hilit=rekey
http://members.cox.net/r1100rs/bmw/rekey.html
http://www.advrider.com/forums/showthre ... vario+case
http://forums.pelicanparts.com/bmw-r110 ... ebags.html
Thanks too all who replied, did as instructed..!.....woked great..one key does it all.
Now..if I'm not stretching my welcome???
Using the full size bag on the left,do i need to replace the pass,foot peg / foot peg bracket?...the bag [locater] hits the bag in a different place. I recieved [some] 'WUDO' parts with the bags i bought,...but i think something is missing?
Thanks again, Ron
Thanks again, Ron
BMW makes a lowering kit for the exhaust, which as well as giving you a lower mount for the muffler, relocates the "foot" for the bag. There's no need to change anything else. If you don't need the exhaust bracket, the fix can be as simple as a couple of short pieces of angle bolted to the bag to locate the "foot" on the footpeg bracket. You should be able to find discussion and pictures in here on this.ron prior wrote:Thanks too all who replied, did as instructed..!.....woked great..one key does it all.
Thanks again, Ron
Seek and ye shall find:BMW makes a lowering kit for the exhaust, which as well as giving you a lower mount for the muffler, relocates the "foot" for the bag. There's no need to change anything else. If you don't need the exhaust bracket, the fix can be as simple as a couple of short pieces of angle bolted to the bag to locate the "foot" on the footpeg bracket. You should be able to find discussion and pictures in here on this.
viewtopic.php?f=2&t=21513&hilit=lowering+left
FWIW - The BMW lowering kit was good quality.
Well thanks again for the help / pictures.
After reading & considering, I think I'll make my own bag [locater]/[holder] in the further out location & use the stock peg & bracket. Lowering the pipe is done.
Might look for a 'cat' eliminator later. Want to live with it quite for a bit first.
Thanks again, Ron
Thanks again, Ron
