I went out to the garage Sunday to check something and noticed a shiny little thing protruding from my rear tire. Its the F650GS with the Battle Wings for rubber. Theres quite a bit of tread left and these are dual sport tires. After inspecting what looked like a nail without the head, I marked the spot and pulled it out with pliers. It was a piece of wire and it had gone in about a half inch but sort of sideways through the rubber. No air leaked out when the metal came out and it has set for 24 hours with no leaking of air at all.
Question for tire experts: When the tire gets hot will it be more likely to exhibit a small leak (hole gets bigger), or will it tend to seal any small hole that may be there? I know the pressure inside the tire will increase with heat, I just don't know how close that piece of metal came to puncturing through and if there's a danger of it "becoming" a hole once it gets hot.
Tire Partially Punctured?
- CycleRob
Re: Tire Partially Punctured?
Boxer,
The answer appears in your own words:
"It was a piece of wire and it had gone in about a half inch but sort of sideways through the rubber. No air leaked out when the metal came out and it has set for 24 hours with no leaking of air at all".
If it went in sideways, that means it did not go thru the fabric layer . . . and more importantly the air stopping rubber layer bonded to the fabric layer on the inside. If it hasn't leaked yet it should be OK, especially since the jabbing wire end has been removed. Like the Aussies would say . . . No worries Mate!
On the other hand, do you carry a tire pluging kit and an air pump?
BTW, I plan on leaving my house about 9am Thursday for the Beakster Bash. We'll talk Wednesday evening.
I do...and I dread having to use them. But stuff happens.On the other hand, do you carry a tire pluging kit and an air pump?
Well, I've ridden almost 1,000 miles since I pulled that piece of metal out, and I believe the tire may be losing air. I checked it before I left for the Bash and it had 42 lbs in it...After a couple of weeks and almost 1K miles, I checked it again yesterday and it had only 41 3/4 lbs. I think I might start worrying in a few days.
Don't rush in to anything........I think I might start worrying in a few days.
It's probably leaking 'cause you didn't win the BMW valve stem covers at the Bash!
Buckster '03R
#543
#543
