Ignition reset procedure
I searched a bit and came up empty screened. What is the procedure to reset the motronic after removing the CCP? I pulled the 5th fuse and then what? I remember something about blipping the thottle with the key on...
- Centurion Moderator!
You're There
With key on but not started, roll throttle to full open and release; repeat 2nd time. Key off. Let's the TPS sense the range of throttle motion and memorize it.
