battery choice other than the Odyssey?
scottybooj
Post by scottybooj »
Ok, I prolly need a new battery. (it's only been 4.7 years) I don't want to change my charger and i don't like the price of the odyssey.
any other quality options?
Scott
Black '50R
Long Island, NY
MikeCam
Centurion Moderator!
Donating Member #: 100
Post by MikeCam »
Panasonic LC-X1220P (VRLA) http://www.digikey.com cat. p. 2218 part P231-ND
Westco 12V20P AGM http://www.westcobattery.com/battery_pa ... id=1&mid=6
Post by CycleRob »
. . . any other quality options?
No.
I have the Odyssey and it is noticeably powerful on frigid cold starts. You will not need a charger for 3 months of inactivity, even if you do not remove the Motronic & clock fuses (which would help).
All other choices will get you less cranking power and a shorter than 8 yr service live. My advice: sacrifice somewhere else for what will be a much better investment for a higher performance, more abuse tolerant battery. Especially if you plan on keeping the bike. Even a year from now if you sell the bike, you'll still be able to trade +$10 with a local member whose stock battery is where yours is now.
You could even turn your bike off with the KS or sidestand and still start it 2 hours later, without harming the battery much - - - although I do not recommend it.
Scott, get the Odyssey and when the May Bash comes around, you can thank me in person.
BigC
Post by BigC »
http://www.batteryplex.com/odyssey-deta ... odel=PC680 It's only around $20 more than an SLA and the thing cranks in just obscene temps. Actually that price has come down since I bought mine. I paid around $130 shipped about 6 months ago.
If your a fair weather rider then I can understand why you'd be reluctant. If your someone that will ride whenever the road conditions are agreeable to two wheels, the Odessey is what you should get...IMO.
'04 R1150R
Post by CycleRob »
I stumbled on this and just had to add it as justification for the premium cost.
It pretty much says it all !!
http://www.odysseybatteries.com/whyodyssey.htm
TicTac50
Donating Member #: 586
Post by TicTac50 »
A+ for Odyssey Battery :-({|= :-({|= :-({|=
"JUST SET IT AND FORGET IT" :D :D :D
Taking the Gas Tank off one extra time will save you $25.00 :roll: :roll: :roll:
Good Luck.
Lifetime Member #586
2002 R1150R
2004 R1150 ABS
2003 F650 CSA
PRESSING "1" FOR ENGLISH!
scottybooj
i'm definitely not fair weather. The stock battery has gotten me over 4.5 years of service in New York with MANY cold starts at/near freezing. that is why I was reluctant to drop the coin.
Scott
Black '50R
Long Island, NY
scottybooj
i saw an adapter for bmw's on one of those sites...what is needed in addition to the battery for use on our R?
thanks
Scott
Black '50R
Long Island, NY
TicTac50
Post by TicTac50 »
I used an adapters L shape. Got them direct from the Odyssey.
http://www.odysseybatteries.com/accesso ... wposts.htm
Very easy to install. :) :) :)
Good Luck.
2002 R1150R
2004 R1150 ABS
2003 F650 CSA
Green Hornet
try this one?
Post by Green Hornet »
http://www.gruberpower.com/gruberpower/ ... pc-680.asp
Have purchased from them before and all is well. :lol:
Micky
Micky
2000 Moto Guzzi Jackal
2004 Rockster - Green
duckdave
Donating Member #: 580
Post by duckdave »
+1 Odyssey (so far).
I just bent the stock terminals to fit, did not use adapters, had plenty of wire.
-duckdave
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
Post by CycleRob »
My L brackets came with the battery without my asking for them. Just like with the previous WestCo maintenance free battery, I had to straighten out the terminal tabs a little for a smooth fit.
http://i142.photobucket.com/albums/r87/ ... BaCoCa.jpg
The pic also shows my 12V pump with added Widder vest type 12V terminal, diagnostic terminal relocate and charcoal canister relocate.
