Large board update
Large board update
Postby Doug » Wed Dec 14, 2016 11:33 pm
We were a little behind on the updates, so I performed a large one tonight. Your preferred style may have changed, but I've added a couple back in, so have a look in your settings and you can choose which one you like. Please let me know if you see anything weird!
Thanks all! Happy Holidays!!
sjbmw
Moderator
Donating Member #: 263
Re: Large board update
Postby sjbmw » Thu Dec 15, 2016 9:28 am
Much different look!
I am too programmed mentally to make the switch right now.
User Control Panel, Board Preferences, subsilver2 in the drop down.
sweatmark
Septuple Lifer
Donating Member #: 208
Postby sweatmark » Thu Dec 15, 2016 1:32 pm
Looks good
Postby Doug » Thu Dec 15, 2016 6:28 pm
Yup, growing pains. Let me know if something really errks you and I'll attempt to fix it. In general I try not to mess with it too much - learned that lesson the hard way over the years, every update tends to break any mods I've done.
I'm suffering from one at the moment - new post approvals are broken. I'm working on it with the ISP admin. Thanks guys, and happy holidays!!!!
Postby Doug » Thu Dec 15, 2016 7:17 pm
Ok, looks like I found out what was wrong.. I did a large home directory backup (4.5gigs!) and when the server did its space check, it started denying any requests that needed space. I put a temp increase on the space and am downloading the backup. Looks to be in order now. Let me know if you guys see anything weird.
Postby Doug » Sat Dec 17, 2016 8:31 pm
Looks ok to me so far. All good for you guys?!
kirby
Donating Member #: 3
Postby kirby » Sat Dec 17, 2016 11:15 pm
Yep, you done good!
mike Mojave CA
'04 ROCKSTER
Return to “Off-Topik!!!!!”
Users browsing this forum: No registered users and 13 guests
