front brake reservoir leaking
Lowzero2
Post by Lowzero2 »
The front brake reservoir is leaking. Looks like it is coming out of the botom of the reservoir. Didn't have time to investigate farther.
Has anyone had this issue happen or know if they are fixable?
RSMike
Re: front brake reservoir leaking
Post by RSMike »
Yes, its a common fault unfortunately, details here on the ever helpful Anton Largiader's web site: http://www.largiader.com/tech/r11mc/
You need BMW p/n 32 72 2 332 037 - rebuild kit and p/n 32 72 2 310 756 - boot, Repair was done by Local BMW dealer on my bike for PO, total cost parts & labor €88. Try and clean away as much of the leaking fluid as you can, it inevitability will damage paintwork on the handlebar lever/switch unit, but you may be able to minimise it until you get the repair done.
1996 R1100R Artic grey
2012 F650GS SE
Lowzero2
Post by Lowzero2 »
RSMike wrote:Yes, its a common fault unfortunately, details here on the ever helpful Anton Largiader's web site: http://www.largiader.com/tech/r11mc/
You need BMW p/n <a href="tel:32 72 2 332 037">32 72 2 332 037</a> - rebuild kit and p/n <a href="tel:32 72 2 310 756">32 72 2 310 756</a> - boot, Repair was done by Local BMW dealer on my bike for PO, total cost parts & labor €88. Try and clean away as much of the leaking fluid as you can, it inevitability will damage paintwork on the handlebar lever/switch unit, but you may be able to minimise it until you get the repair done.
Great! Thank you for the quick info
captaincable
Donating Member #: 1050
Post by captaincable »
I think you can get the kit at beemer boneyard could not get a rebuild for the rear on mine but noticed the front kit when I ordered a new rear master.
Mike
Lowzero2
Post by Lowzero2 »
captaincable wrote:I think you can get the kit at beemer boneyard could not get a rebuild for the rear on mine but noticed the front kit when I ordered a new rear master.
Mike
Thank you
WineGuyD
Post by WineGuyD »
Had the same problem on my 1996 R1100r with just 17k miles. First tried rebuild kit but in the end still leaked due to internal corrosion, ended up with new master cylinder unit from Beemer boneyard and wasted the time and money on rebuild kit. Consider that before making a purchase. BTW, you would be wise to replace your brake lines while you're at it.
Eli the wine guy
uberchin
Post by uberchin »
