R1100R inside tank and cannister lines diagram needed
R1100Ryder
Does anyone have a diagram of the lines inside of the gas tank and cannister lines? Just bought a used 1999 R1100R and wanted to make sure they were not misdirected when the previous owner switched the fuel filter.
Re: R1100R inside tank and cannister lines diagram needed
If the engine runs and you can take her for a ride then everything is fine and there is no need to make sure ...
Apart of that I suggest you fetch yourself the maintenance manual which you can download at http://www.carlsalter.com/motorcycle-manuals.asp
Best regards
Oliver
Best regards
Oliver
R1100Ryder
