Abs light on
bhmav8r
Abs light on
Post by bhmav8r »
ABS light on my 2008 R1200R stays on. :(
Haven't had any problems before. Today was first time to ride after about four months.
Searched the board and found out about the ABS issues with the motor and probably a rebuild by Module Masters.
I plan to take it to a dealer (there is not one currently in my area but should be a new one in a few months) for the fuel strip and fuel pump recall and have the codes read/cleared.
My question is - what else can I trouble shoot beforehand?
Thanks in advance! =D>
Re: Abs light on
Check your battery voltage and make sure it's healthy, I've seen a failing battery throw ABS faults.
Also make sure the ABS sensor are clean and all the connections secured, I've had the ABS light come from a dirty sensor.
Good luck!
Dr. Strangelove
Re: Abs light on
Post by Dr. Strangelove »
and perhaps stating the obvious, You don't have ABS so brake accordingly
'09 Schwarze Blanche DuBois
