ABS light on my 2008 R1200R stays on.
Haven't had any problems before. Today was first time to ride after about four months.
Searched the board and found out about the ABS issues with the motor and probably a rebuild by Module Masters.
I plan to take it to a dealer (there is not one currently in my area but should be a new one in a few months) for the fuel strip and fuel pump recall and have the codes read/cleared.
My question is - what else can I trouble shoot beforehand?
Thanks in advance!
Abs light on
Re: Abs light on
Check your battery voltage and make sure it's healthy, I've seen a failing battery throw ABS faults.
Also make sure the ABS sensor are clean and all the connections secured, I've had the ABS light come from a dirty sensor.
Good luck!
Good luck!
- Dr. Strangelove
- Double Lifer
Re: Abs light on
and perhaps stating the obvious, You don't have ABS so brake accordingly
