Is my mechanic having a go?
R1150r 2001
I need a new clutch he quoted a clutch plate and a clutch housing in the parts. Motorworks in the UK have a clutch kit and it includes:
1 - Housing Cover
2 - Clutch Plate
3 - Pressure Plate
4 - Diaphragm Spring
5 -Assorted bolts
BUT NO Clutch housing. The housing is the most expensive bit.
Q1 - Is it normal to replace the clutch housing when replacing a clutch?
Q2 - Is it worth the extra expense to buy an oil resistant clutch plate?
Q3 - Some folk have an issue where the input shaft gets worn where it meets the clutch plate and it ratted. I have seen a plate which goes onto the clutch plate and makes the socket deeper to engage the shaft more solidly. What do folk think of it?
Replacing a clutch
Replacing a clutch
