So far, I've changed the oil & filter, adjusted the valves, replaced the spark plugs, and replaced the air filter with a k&n.
Today I removed the tank and replaced the fuel filter. All went smooth, until I put the tank back on, and it wobbles. We're talking about an unacceptable level of wobble here, coming from the front of the tank, it rocks back and forth on the two nubs it's resting on. The bolt in back is torqued to spec (22Nm), and the tank sits as flush as it will, but those rubber thingies it sits on up front are not flush top to bottom.
Anyone else had this problem? Am I forgetting a bolt or something else? Kind of a dumb problem.
(By the way, the bike's a dream, super clean, no dings, well-maintained - looks practically brand new. Runs like a champ, I had no problems at all on the whole 3000+ miles Sturgis run.)
