14 month lay off
Posted: Wed Mar 27, 2019 8:36 am
by riceburner
So - the big K has been in the garage for year and more, what might have 'gone wrong' with it?
I'm going to put it back on the road in the next week or two, and I'm hoping that all it'll need is a fuel drain (if possible, I don't have access to all my usual tools), and maybe a pump of the (newly fitted at the time of putting away) tyres.
The battery has been in a warm(ish) garage and will get a good charge beforehand so I don't anticipate any issues there.
Re: 14 month lay off
Posted: Fri Mar 29, 2019 8:11 am
by sweatmark
I dread starting my K1300 after long resting period, especially when conditions are cold. The first few seconds after starting are traumatic, waiting for cam chain tensioner to pressurize with cold thick oil, and cam chain makes horrific rattle. I'm thinking about installing the manual tensioner as alternative.
Other than cam chain rattle, the modern K bikes are tight and tidy. Yes, I would hope you could replace or supplement old fuel with fresh, and check the brake & clutch hydraulics. But otherwise, the CAN-BUS will report any problems. What I gather from other K owners is that the bikes either just work, or fail spectacularly.
Posted: Fri Mar 29, 2019 11:15 am
by riceburner
sweatmark wrote:I dread starting my K1300 after long resting period, especially when conditions are cold. The first few seconds after starting are traumatic, waiting for cam chain tensioner to pressurize with cold thick oil, and cam chain makes horrific rattle. I'm thinking about installing the manual tensioner as alternative.
Sounds about right. Tbh I've never had any issues with 6 month storage on bikes, i doubt this will be any different.
Posted: Tue Apr 02, 2019 9:27 am
by riceburner
So far so good!
The Beast fitted up first press of the button and settled down to a smooth tickover as if I put it away only yesterday!
Little bit of a oil drip manifested on the right front corner on the cam-cover seal, I'm hoping that is just a very cold seal that will expand and close up..... Fingers crossed.
Rode it up and down the lane and the brakes aren't even binding!!
Next.... MOT.
Posted: Tue Apr 02, 2019 3:28 pm
by riceburner
YAY! Clean pass! And the ride home after filling with 99octane was absolutely fine.
IT LIVES!
Posted: Tue Apr 02, 2019 8:14 pm
by sweatmark
riceburner wrote:YAY! Clean pass! And the ride home after filling with 99octane was absolutely fine.
IT LIVES!
Posted: Sat Apr 06, 2019 7:23 am
by riceburner
sweatmark wrote:riceburner wrote:YAY! Clean pass! And the ride home after filling with 99octane was absolutely fine.
IT LIVES!
Indeed!
And now to sell it.....
I hanker for a Rockster again.
Posted: Sat Apr 06, 2019 2:04 pm
by sweatmark
riceburner wrote:sweatmark wrote:riceburner wrote:YAY! Clean pass! And the ride home after filling with 99octane was absolutely fine.
IT LIVES!
Indeed!
Welcome home! You've been missed.
Posted: Tue Oct 08, 2019 2:50 am
by riceburner
sweatmark wrote:riceburner wrote:sweatmark wrote:
Indeed!
6 months later and I still have the Beast.....
Currently sitting idle with a flat tyre after a month of commuting. Need to get it sorted again now the Rockster needs TLC. #itneverends.
